How we can access the attribute from data leyer in a Web Map? For exmaple, I have a web map with weather stations. I need to develop a custom widget on Experince Builder, when I click on station, widget should take stationID from attribute and then run on API to take real time data?
import { React, AllWidgetProps } from "jimu-core";
import { JimuMapView, JimuMapViewComponent } from "jimu-arcgis";
import { useState } from "react";
export default function RealTimeStationWidget(props: AllWidgetProps<any>) {
const [stationData, setStationData] = useState<any>(null);
const [mapView, setMapView] = useState<JimuMapView | null>(null);
const onActiveViewChange = (jmv: JimuMapView) => {
console.log("✅ Active view set", jmv.view);
setMapView(jmv);
jmv.view.on("click", async (event: any) => {
console.log("🟡 Map clicked");
const hit = await jmv.view.hitTest(event);
console.log("🔍 Hit test result:", hit.results);
for (let i = 0; i < hit.results.length; i++) {
const attr = hit.results[i].graphic?.attributes;
console.log(`🎯 Graphic ${i} full attributes:`, attr);
console.log(
`🎯 Attribute keys:`,
attr ? Object.keys(attr) : "No attributes"
if (attr && attr.stasjonID) {
console.log("✅ Found stasjonID:", attr.stasjonID);
const stationId = attr.stasjonID;
const data = await fetchStationData(stationId);
setStationData(data);
return;
Place this outside the for-loop to log only once if none matched console.warn("
No stasjonID found in clicked graphics."); });
const fetchStationData = async (stationId: string) => {
const apiKey = "xyzxyzx";
let waterLevel = "N/A";
let waterFlow = "N/A";
let waterTemp = "N/A";
let timestamp = "N/A";
try {
const res1 = await fetch(
`${url}?StationId=${stationId}&Parameter=`,
headers: { accept: "application/json", "API-Key": apiKey },
const json1 = await res1.json();
if (json1.data?.[0]?.observations?.[0]) {
waterLevel = json1.data[0].observations[0].value;
timestamp = json1.data[0].observations[0].time;
} catch (e) {
console.error("Water level error:", e);
try {
const res2 = await fetch(
const json2 = await res2.json();
if (json2.data?.[0]?.observations?.[0]) {
waterFlow = json2.data[0].observations[0].value;
if (timestamp === "N/A") timestamp = json2.data[0].observations[0].time;
} catch (e) {
console.error("Water flow error:", e);
try {
const res3 = await fetch(
const json3 = await res3.json();
if (json3.data?.[0]?.observations?.[0]) {
waterTemp = json3.data[0].observations[0].value;
if (timestamp === "N/A") timestamp = json3.data[0].observations[0].time;
} catch (e) {
console.error("Water temp error:", e);
return { stationId, waterLevel, waterFlow, waterTemp, timestamp };
return (
<div style={{ padding: "1rem" }}>
<JimuMapViewComponent
useMapWidgetId={props.useMapWidgetIds?.[0]}
onActiveViewChange={onActiveViewChange}
<h3>Real-Time Station Data</h3>
{stationData ? (
<div>
<p>
<strong>Station ID:</strong> {stationData.stationId}
</p>
<p>
<strong>Water Level:</strong> {stationData.waterLevel} m
</p>
<p>
<strong>Flow:</strong> {stationData.waterFlow} m³/s
</p>
<p>
<strong>Temperature:</strong> {stationData.waterTemp} °C
</p>
<p>
<strong>Time:</strong> {stationData.timestamp}
</p>
</div>
<p>Click a station to view real-time data</p>
</div>
