I'd like to discuss the new export raster as single tile feature when exporting PDF layouts in ArcGIS Pro 3.5 and the issues surrounding raster content. There have be conversations about this in the past but I thought I'd start a new one now because 3.5 is out and my issue is specifically talking about Blend Mode. Here is the most active thread I have read through.
- Look through my notes and let me know if you've experienced the same issue
- I would love to hear from someone at ESRI about this behavior and the expected results.
For reference here is what the release notes it states about the Export raster content as single tile setting:
"You can use the Export raster content as a single tile option to avoid thin line artifacts between tiles of transparent raster, rasterized, and vector tile layers. These artifacts appear in some viewing applications for PDF and SVG exports."
Original Issue:
The original issue I was hoping this new setting would fix is the boundary of our raster poorly blending into our layers. We use Multiply blend mode with a hillshade raster that purposely only goes to the border of our parks so they pop-out in contrast to the surrounding neighborhood and other parks that our park district does not operate. Pdf attached with "_335" in the title shows this.
The workaround to change Adobe Viewer settings that I've seen mentioned is not something that we can do as the maps are for public consumption. There are some other workarounds we've played around with such as using a line layer that goes on top of the blend layer that is the exact shape of the hillshade using raster domain.
New Issue:
Using Pro 3.5 I have just tried out the new export setting with the same layout and the result is rather strange and does not resolve "Original Issue" I mentioned earlier. The new issue is that the coloration is completely off from what it shows in ArcGIS Pro, that makes it unusable. See attached pdf with _35_rastersingletile" in the title to see this.
