I am working to generate a report from a generated arcgis template form. All the fields should be correct from the sample. However, I am receiving this error message, "An error occurred when checking the report template. Failed to parse ${Monitor} since it is an invalid expression." Monitor is the correct name for the name column. Why is this coming up as an invalid expression when the name of the data title is correct?
