I have point features related to a feature-linked annotation feature class that are generated based on specific SQL query parameters. When I add a band new feature to my feature class, a feature-linked annotation is not automatically generated because the new feature does not meet the parameters of the labeling SQL query at the time of creation. When I modify the attributes of the feature after it has been created to satisfy the SQL query an annotation is still not created.
Based on a thread that I've found online, created feature needs to satisfy the SQL query when it gets created. This was confirmed when I copied existing features that meet the SQL query parameters and annotations were created automatically. Is there a work around for new features that may not meet the SQL query parameters right away? The forum links to a geonet.esri.com solution that is no longer accessible.
Original GIS StackExchange Post (From 8 years ago):
https://gis.stackexchange.com/questions/216107/feature-linked-annotation-not-added-when-new-features-are-drawn
Feature linked annotation not added when new features are drawn
I created feature linked annotation for a line feature class. Both the feature and the annotation are feature classes stored within the same feature dataset on an SQL Server Geodatabase.
The initial labeling made use of a simple SQL query which may or may not be relevant. The annotation was created successfully but I'm having a hard time maintaining it due to the following:
- When I create a new feature that matches the filtering requirements of my feature linked annotation, the annotation is not created automatically. Instead I have to select the feature and then click Selection > Annotate selected features. It's my understanding from reading through ESRI's help that the annotation should be created automatically for any newly added features. These new features DO match the sql query I initially made use of.
Answer:
I have ran into this problem before and this seemed to work for me.
https://geonet.esri.com/thread/52888
The SQL Query is exactly what's stopping the annotation from getting created.
The composite relationship class allows for new annotation to get created as soon as a new feature in the related feature class is created. This process only happens at the exact moment that the new feature is committed to the database (before you ever modify attribute information). When a SQL Query is being used to limit the annotation that is seen in a particular anno class, the value(s) which match the SQL query must be present at the time the feature is created for the related anno to get created as well. In your case, they're not.
