Some users are signed out 0-5 times a day when submitting surveys.
The workflow is integrated with Field Maps (callback on submission).
There is no pulldata @ layer or editing existing values.
Logs on event occurence below.
Anyone have any ideas? Latest version Connect and field app.
Suspecting it's tied to low/intermittent connectivity but thought all these defects were fixed...
<12>1 2025-05-27T01:46:17Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="default"] stale focus object 0x300e208f0 , doing manual update
<15>1 2025-05-27T01:46:17Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="qml" function="closePage" filename="AppPage.qml" line="314"] qml: backPage undefined
<15>1 2025-05-27T01:46:17Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="AppSettings" function="write" filename="AppSettings.qml" line="451"] AppSettings: Writing app settings - /var/mobile/Containers/Data/Application/96CDAC80-137D-403E-8CA2-xyzxyzxyzxyz/Documents/ArcGIS/AppStudio/Settings/1b899f24e9354a459a2ab2exxxxxxxxx.json
<12>1 2025-05-27T01:46:17Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="default"] stale focus object 0x300e94160 , doing manual update
<12>1 2025-05-27T01:46:21Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="default"] stale focus object 0x300e832e0 , doing manual update
<15>1 2025-05-27T01:46:21Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="qml" function="closePage" filename="AppPage.qml" line="314"] qml: backPage undefined
<12>1 2025-05-27T01:46:21Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="default" filename=""] <Unknown File>: QML QQuickAnchors: Binding loop detected for property "margins"
<15>1 2025-05-27T01:46:21Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="HomeViewTabs" function="updateVisibleCount" filename="HomeViewTabs.qml" line="86"] HomeViewTabs: visibleCount: 1
<12>1 2025-05-27T01:46:22Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="default"] stale focus object 0x300e5da20 , doing manual update
<15>1 2025-05-27T01:50:00Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="455"] Portal: Application state changed: 2
<15>1 2025-05-27T01:50:01Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="455"] Portal: Application state changed: 0
<15>1 2025-05-27T02:02:44Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="455"] Portal: Application state changed: 2
<15>1 2025-05-27T02:02:45Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="455"] Portal: Application state changed: 4
<15>1 2025-05-27T02:02:45Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="onRunningChanged" filename="Portal.qml" line="1000"] Portal: Token expiry timer disabled
<15>1 2025-05-27T02:02:45Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="onRunningChanged" filename="Portal.qml" line="998"] Portal: Token expiry timer will trigger in 11.9488 minutes
<15>1 2025-05-27T02:02:45Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="reset" filename="Portal.qml" line="1016"] Portal: Reset token expiry timer: Tue May 27 12:15:41 2025 GMT+1000 minutes: 11.9488
<15>1 2025-05-27T02:02:45Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="455"] Portal: Application state changed: 2
<15>1 2025-05-27T02:02:47Z localhost ArcGISSurvey123 42515 - [AppStudio@11205 category="Portal" function="onStateChanged" filename="Portal.qml" line="455"] Portal: Application state changed: 0
