We're still working on the transition from ArcMap 10.6.1 to ArcGIS Pro, currently looking at 3.5, parcel fabric version 5, and Enterprise 11.2.
Our current workflow in ArcMap, once we finish the traverse, the lines are all selected, allowing us to then use the the rotate tool to "fit" the parcel into the current linework. ArcGIS Pro, does not seem to work this way and it is a big concern my supervisor has regarding how we will replicate this workflow in Pro. If it's a simple traverse, selecting the line (turning topology off by what I've read), would allow the rotation. However, the selection process can be tedious for larger traverses.
If there is not a way to have those lines selected at the end of a traverse, can someone help me explain why and how the fitting of parcels works in Pro? My understanding with traverses in Pro is that the lines are being inputted into the fabric as you go; where as ArcMap it was a sketch until it was committed. I think, align parcels is what is used to fit parcels within the fabric and not rotating lines to fit. Is that correct?
