Hi Everyone,
I'm using Survey123 Connect v3.22.49 to publish a lengthy form XLSForm to ArcGIS Online.
My XLSForm, although long, is quite simple, it contains a series of groups (collapsible sections) and no repeats. I've published the form successfully and all appears to be working and I'm able to view, use, and submit on the web version.
However, I further wanted to customize the form by leveraging 'generated_notes_prompt_submitted' in my XLSForm and thats when problems arose. I'd like to customize the post submission screen however when I add the generated note to do this it "breaks my form" in survey123 connect (preceding questions not behaving correctly) and when I try to publish it gets stuck on 'Checking Feature Service' and just hangs to the point that I have to close Survey123 connect and re-launch.
It's strange because I have another form where I have this working with no issue at all.
Anyone run into this issue? Or found a workaround/solution?
Paul
