A customer would like to generate a data model via ArcGIS Pro 3.1 in a SQL Server Arc SDE. The basis for this is an existing data model in another system. I have noticed that some attribute names in the SDE are supplemented with an underscore (e.g. "level" becomes "level_"), probably because they are keywords. I have two questions about this:
1.
Do the affected attribute names depend on the underlying database system (are they possibly keywords of the underlying database system)?
2.
Is there a list of attribute names which, as in our case "level", are supplemented with an underscore when the data model is defined or which may/may not be used for a specific reason?
Thank you very much for your help and best regards,
Jürgen
