We use a dashboard for employee performance reviews for the end of our ski season. Info for this dashboard comes from a daily record survey we fill out every morning saying who is on duty, who called out sick, who is off campus for a work thing, etc.
The survey questions are multiple select type. I can't seem to get the indicator to accurately show the number of times a name has been selected in the survey results for the questions. Adjusting the data to show the statistic as a count for the "On duty" field yields "0" in the indicator unless the selected name is the only answer selected for a date. For example, when the employees are selected for the "On duty" question, which always has more than one name selected for the multiple select question type, the indicator does not single out how many times a name is selected for this field when the dashboard is filtered by name using the category selector in the header. Is there any way to fix this so the indicator can read every instance a name is selected whether they are the only selection or not?
