Hi all,
We're facing an error in Survey123, specifically when trying to add attachments/photos to a record opened from the Inbox using the field apps (both desktop and mobile versions). New records can be created and submitted with this form (including pictures), attributes can be edited from the inbox, but pictures cannot be uploaded from the inbox. Only shows a basic "Send Error Surveys not sent: 1" message. The S123 logs show an error code 10500, but so far we haven't been able to find what's causing it.
For context, this is happening specifically in an Enterprise 11.2 environment. Both the form and the survey have been recreated and tested, the error is still reproduced. However, on another Enterprise environment or AGOL the error does not occur, using the same form. It's quite a simple form, so the issue must be within this one Enterprise environment.
Any ideas of what we should be looking at? So far the portal/server logs haven't given us many clues.
