Recently started using ArcGis Pro after using ArcMap for years, and I haven't used ArcMap for a while before making the switch. I am trying to import points to a map using UTM coordinates which is what the map is using. I get an error message saying the features have invalid geometry. I've done this hundreds of times in ArcMap. I can't figure out if I'm setting up the table wrong or where the invalid geometry is.
Do I need to include the zone in my Easting or Northing coordinates? I had it in a column but that column does not appear when selecting columns for easting and northing.
I know it's a simple fix, just can't find it.
