Hi Community; New day, new question. In catalog, I am wishing to use Data Design to add a field to the attribute table for a feature layer. Something I have done many times with this procedure. I have the attribute table for the desired layer called up via the contents pane. But in the catalog pane when expanding everything in the correct gdb for this project, the desired layer is not listed. Now, to investigate this when looking at properties for this layer in the contents pane and looking at the source path file, it is indeed the correct gdb that I am looking at in the catalog pane.
Why does the desired, valid, existing layer in the contents pane not show up in the catalog view of the correct and corresponding gdb?
Thanks again for ideas! Dave
