I want to have url parameters that will zoom to a particular parcel based on the property ID attribute in a field in my organization's parcels layer using my Experience Builder app. I have set up the Search widget per an earlier Esri Community post on this subject. However, I can't seem to get this to work. For example, I'll generate the URL after searching for a particular property - then I'll change the property ID value in the URL to a different one and the map will remain at the original location rather than zooming to the new property. This seems to be related to a string that appears after the data source ID - this changes each time I search for a different property ID (see red bolded text in the generated urls below. The green bold is the parcel property ID.
Can anyone explain what this string is and why it changes or have some advice on how I get a working url parameter that will accomplish what I'm looking for?
Thank you,
Samara
https://experience.arcgis.com/experience/a2380710835a4b8bb9fd9021adea8bd9?org=worcesterma#data_s=id%3AdataSource_1-1958b01346c-layer-111-1958f6aef5c-layer-79-1958b0135c2-layer-114%3A26983&widget_3=search_status:%7B%22searchText%22%3A%2208-005-00018%22%7D&zoom_to_selection=true
https://experience.arcgis.com/experience/a2380710835a4b8bb9fd9021adea8bd9?org=worcesterma#data_s=id%3AdataSource_1-1958b01346c-layer-111-1958f6aef5c-layer-79-1958b0135c2-layer-114%3A25358&widget_3=search_status:%7B%22searchText%22%3A%2203-008-00005%22%7D&zoom_to_selection=true
