Hello, I am having an issue getting all of the values from my table written into the .xls I can get a single row, but need all of the columns.# Use row object to get and set field values cur = arcpy.SearchCursor(data_source) # Set up workbook and sheet book = Workbook() sheet1 = book.add_sheet('Points') # Set counter rowx = 0 # Loop through rows in dbf file. arcpy.AddMessage(cur) for row in cur: rowx += 1 # Write each row to the sheet from the workbook. Set column index in sheet for each column in .dbf sheet1.write(rowx,0,row.ID) book.save('C:/Output') print"Export finished" In the line sheet1.write(rowx,0,row.ID)
I need 3 parameters where rowx = walks through and gets all values in every row - 0 = column index of where the values are written in the xls & row.ID = the column that is being written from table.Any help is greatly appreciated.
