Hi all,
I have built a questionnaire in survey123 connect and would like the ability to pre-populate as much as the information as possible before sending to clients in order to reduce the amount of manual input required.
So far I have used a pulldata() function to pre-populate non-repeat questions from a client_data.csv file stored in the surveys media folder using the client_id as the look up column. I have then used a URL parameter to feed the client_id to the survey and pre-populate the information below.
https://survey123.arcgis.com/share/141c94cfee124e5f8b2944000a6e9e10?field:client_id=123
However, this method does not work for the repeat questions within my survey. Is it possible to pre-populate repeat questions and if so how?
