Hi there community!
I am really hoping for some help on this, it is driving me mad! I have an Arcade script being used in an indicator widget in a dashboard on10.9.1 Portal and works great. I am migrating same dashboard and widget to 11.3.1. I copied the original script to new dashboard, changed the Portal location, service id, layer id, and the fields I pull in are identical. The script is just doing a Groupby function to create a table with a handful of existing fields plus two new fields that are calculated. The first one is using a multiply math operator and works fine. The second expression is using division and I get a "Test execution error: Unknown Error. Verify test data.
I have commented out the second expression and the script works, so I know it is good up to there. If I change the division operator to addition, subtraction, or multiplication, it also works, just not the value I need.
Any help or thoughts are greatly appreciated, Thanks!
Script where second expression doesn't work:
var tvwdportal = Portal('https://acadia.tvwd.org/portal')
var flush = FeatureSetByPortalItem(tvwdportal,"4159ad26944145339b8ae97ea484c331",70,['Duration', 'EstimatedFlushTime', 'Turbidity','StartTime', 'StopTime','assetid'],true)
groupby(
flush,
["StopTime", "assetid", "Turbidity","EstimatedFlushTime", "Duration",
{name:'EstimatedTimex2', expression: 'EstimatedFlushTime * 2', statistic: 'MAX'},
{name: 'PipeVolumeTurnover', expression: 'Duration / EstimatedFlushTime', statistic: 'SUM'}
Script and table if I change operator on second expression (Line11)
groupby(
flush,
{name: 'PipeVolumeTurnover', expression: 'Duration * EstimatedFlushTime', statistic: 'SUM'}
StopTime assetid Turbidity EstimatedFlushTime Duration EstimatedTimex2 PipeVolumeTurnover ROW__ID
| null | "FLSH105902" | null | null | null | null | null | 149875 | |
| null | "FLSH105911" | 1 | 21.90297563 | 60 | 43.805951 | 1314.178538 | 150675 | |
| null | "FLSH105985" | 1.54 | 4.23492962 | 30 | 8.469859 | 127.047889 | 159472 | |
| null | "FLSH105987" | null | null | null | null | null | 159872 | |
| null | "FLSH106037" | null | null | null | null | null | 165475 | |
| null | "FLSH106067" | null | null | null | null | null | 167875 | |
