Hey everyone,
I’m new to Power Automate, and we’re transitioning from ArcGIS Online to ArcGIS Enterprise in a few weeks. As we make this switch, a common question has come up: Can we edit feature layer data through Excel?
I know ArcGIS for Excel is an option, but in ArcGIS Online, users needed a Creator license to pull in and edit an attribute table—which costs around $700 per year.
For ArcGIS Enterprise (we’re getting the Standard version), I’m looking into whether Power Automate can be used to:
- Connect to feature layer attributes
- Pull that data into Excel
- Allow updates to be pushed back to the feature layer
From what I understand, this should be possible—but does it still require a Creator license? Or does ESRI licensing not impact this, meaning even a Viewer could make changes?
I’m also curious about sharing this setup. If I configure the ArcGIS Enterprise connector to allow users to pull in and edit attribute tables, is there an easy way to share this setup with others? Not sure if I’m using the right terminology, but hopefully, my question makes sense!
Apologies if anything is unclear—I’m still learning. I’d really appreciate any insights!
