I was happy to see the implementation of scale limits for maps within experience builder. However, I'm running into some unusual behavior with mine. My map has many cache layers in it and right now they are all cached down to the 282 scale. I've been playing around with setting the map scale limit at 282. I have the search widget in my experience and one of the layers you are able to search is parcels. I have the search tool set up with the action to select and zoom to a parcel after a successful search is done. The zoom is set to automatic zoom scale. Currently if you search for a smaller parcel it zooms down to the 282 scale, but my cache layers disappear as if it the current scale level is outside the cached scales. Even more peculiar is that if I set the map scale limits to 283 and repeat the process it then zooms down only to the 564 scale. And after this is done you are not even able to manually zoom the map in beyond 564 using either the scroll wheel or the map zoom buttons.
