Hi all,
I've been encountering issues with publishing surveys in ArcGIS Survey123. The error message is blank/not helpful (just a set of curly brackets). If I copy a survey the error follows it. Last time this happened, I tried deleting questions one by one to find where the issue was, but it persisted even with an essentially empty survey & form. I created a new survey and copied the questions in manually such that it was an exact copy of the one with the error, and was able to publish it. Now I encounter the issue again and want to actually solve it this time...
If anyone has any insights on what the issue may be/how to fix it, it would be much appreciated!
