I'd like to query a hosted layer and add the output to my map using ArcGIS API for JS 4.11. I'm creating a Park Finder application, and the goal is for different parks to appear on the map according to amenities that are checked. I've been following the documentation for the Query and QueryTask modules and looking at the sample code in the QueryTask example: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=tasks-query.
However, I can't seem to get the results to add to my map. At the moment, my test application is supposed to return one park named Rouge Park when I check the "Basketball" checkbox, but nothing appears on the map when I check the checkbox. Printing to the console, I can tell that the queried object is successfully making it to the final function where I ultimately add the result (lines 346-365). Am I adding the result incorrectly? Apologies for copying my entire code... lines 61-210 essentially create dummy content.
Any help would be very appreciated.
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta content<SPAN class="operator token">=</SPAN><SPAN class="string token">"IE=edge,chrome=1"</SPAN> http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"X-UA-Compatible"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1, user-scalable=no"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1.0"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://www.waynecounty.com/ui/css/jquery.mmenu.all.css"</SPAN> rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/css"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link href<SPAN class="operator token">=</SPAN><SPAN class="string token">'https://www.waynecounty.com/ui/css/semantic.min.css'</SPAN> rel<SPAN class="operator token">=</SPAN><SPAN class="string token">'stylesheet'</SPAN> type<SPAN class="operator token">=</SPAN><SPAN class="string token">'text/css'</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://ajax.googleapis.com/ajax/libs/jquery/3.4.0/jquery.min.js"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">'https://www.waynecounty.com/ui/lib/semantic.min.js'</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN>JS Scripts to print map<SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://cdnjs.cloudflare.com/ajax/libs/jspdf/1.3.2/jspdf.min.js"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://cdnjs.cloudflare.com/ajax/libs/html2canvas/0.4.1/html2canvas.min.js"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://cdnjs.cloudflare.com/ajax/libs/javascript-canvas-to-blob/3.14.0/js/canvas-to-blob.js"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://cdnjs.cloudflare.com/ajax/libs/FileSaver.js/1.3.8/FileSaver.js"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.11/esri/css/main.css"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN><SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"manifest"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"/manifest.json"</SPAN><SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN>ArcGIS API <SPAN class="keyword token">for</SPAN> JavaScript<SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.11/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>The Wayne County ParkFinder<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN> body <SPAN class="punctuation token">{</SPAN>
margin<SPAN class="punctuation token">:</SPAN> 0px<SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
#map_canvas <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN>
top<SPAN class="punctuation token">:</SPAN> 0px<SPAN class="punctuation token">;</SPAN>
left<SPAN class="punctuation token">:</SPAN> 0px<SPAN class="punctuation token">;</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> #F5FFFA<SPAN class="punctuation token">;</SPAN>
#overviewDiv <SPAN class="punctuation token">{</SPAN>
bottom<SPAN class="punctuation token">:</SPAN> 55px<SPAN class="punctuation token">;</SPAN>
left<SPAN class="punctuation token">:</SPAN> 30px<SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> 300px<SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> 200px<SPAN class="punctuation token">;</SPAN>
border<SPAN class="punctuation token">:</SPAN> 2px solid black<SPAN class="punctuation token">;</SPAN>
z<SPAN class="operator token">-</SPAN>index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">997</SPAN><SPAN class="punctuation token">;</SPAN>
overflow<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN>
#extentDiv <SPAN class="punctuation token">{</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> <SPAN class="token function">rgba</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
z<SPAN class="operator token">-</SPAN>index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">998</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui small top fixed teal inverted menu"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>a <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"browse item"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"color: white; font-size: 14px; font-weight: bold;"</SPAN><SPAN class="operator token">></SPAN>
Park Features
<SPAN class="operator token"><</SPAN>i <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"large dropdown icon"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>i<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>a<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui fluid popup"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"top: 553px; left: 1px; bottom: auto; right: auto; width: 960px;"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui six column relaxed equal height divided grid"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN>column<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>h4 <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui header"</SPAN><SPAN class="operator token">></SPAN>Trails <SPAN class="operator token">&</SPAN> Fitness<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h4<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui checkbox"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">"checkbox"</SPAN> name<SPAN class="operator token">=</SPAN><SPAN class="string token">"ccSki"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Cross Country Skiing<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>br<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">"checkbox"</SPAN> name<SPAN class="operator token">=</SPAN><SPAN class="string token">"filler"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">1</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>h4 <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui header"</SPAN><SPAN class="operator token">></SPAN>Sports <SPAN class="operator token">&</SPAN> Games<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h4<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui checkbox featureCheck"</SPAN> data<SPAN class="operator token">-</SPAN>rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"bball"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">"checkbox"</SPAN> name<SPAN class="operator token">=</SPAN><SPAN class="string token">"bball"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Basketball<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">"checkbox"</SPAN> name<SPAN class="operator token">=</SPAN><SPAN class="string token">"vball"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Volleyball<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">"checkbox"</SPAN> name<SPAN class="operator token">=</SPAN><SPAN class="string token">"rackball"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Racketball<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>h4 <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui header"</SPAN><SPAN class="operator token">></SPAN>Water Recreation<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h4<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">2</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">3</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>h4 <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui header"</SPAN><SPAN class="operator token">></SPAN>Outdoor Recreation<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h4<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">4</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">5</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>h4 <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui header"</SPAN><SPAN class="operator token">></SPAN>Winter Recreation<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h4<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">6</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">7</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>h4 <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ui header"</SPAN><SPAN class="operator token">></SPAN>Amenities <SPAN class="operator token">&</SPAN> Fitness<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h4<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">8</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label<SPAN class="operator token">></SPAN>Filler Amenity <SPAN class="number token">9</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN>Map div<SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map_canvas"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> myView<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Basemap"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/VectorTileLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/ScaleBar"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/MapImageLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/QueryTask"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/support/Query"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> Basemap<SPAN class="punctuation token">,</SPAN> VectorTileLayer<SPAN class="punctuation token">,</SPAN> ScaleBar<SPAN class="punctuation token">,</SPAN> MapImageLayer<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> QueryTask<SPAN class="punctuation token">,</SPAN> Query<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//The URL of the Parks Map Service that will queried</SPAN>
<SPAN class="keyword token">var</SPAN> parksMapServiceURL <SPAN class="operator token">=</SPAN> <SPAN class="string token">"https://devarcgisent.waynecounty.lan/serverdev/rest/services/ParkFinder/Wayne_County_Parks/MapServer/0"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//The popup template and symbology for the search results</SPAN>
<SPAN class="keyword token">var</SPAN> resultsPopupTemplate <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"{Parks_NAME}"</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"<b>Owner:</b> {Parks_OWNE}<br><b>Park Location:</b> {Park_Attri}<br><b>Basketball:</b> {Park_Att_4}"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> parkSymbol <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-fill"</SPAN><SPAN class="punctuation token">,</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">51</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">51</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">204</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.9</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"solid"</SPAN><SPAN class="punctuation token">,</SPAN>
outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"white"</SPAN><SPAN class="punctuation token">,</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="comment token">//Graphics layer for displaying the query results</SPAN>
<SPAN class="keyword token">var</SPAN> resultsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Point the QueryTask to the Map Service URL</SPAN>
<SPAN class="keyword token">var</SPAN> qTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> parksMapServiceURL
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Set the query parameters to always return geometry and all fields</SPAN>
<SPAN class="keyword token">var</SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
returnGeometry<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
where<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Parks_NAME = 'Rouge Park'"</SPAN> <SPAN class="comment token">//This will be changed to be more dynamic. For now keep this here.</SPAN>
<SPAN class="comment token">//Create the main map, starting with a custom basemap loaded from ArcGIS Online</SPAN>
<SPAN class="keyword token">var</SPAN> basemap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Basemap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
baseLayers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">VectorTileLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ddef64bb74174dd6adf7cff46dd24da7"</SPAN>
map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> basemap<SPAN class="punctuation token">,</SPAN>
layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>resultsLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">//Add graphics layer to the map</SPAN>
sliderPosition<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom-right"</SPAN>
<SPAN class="comment token">//Add Wayne County boundary - number in the map.add function indicates the z-index.</SPAN>
wayneCoBoundary <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://devarcgisent.waynecounty.lan/serverdev/rest/services/WayneCoBaseMapApp/WayneCoBoundary/MapServer"</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>wayneCoBoundary<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">20</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Add Parks layer - number in the map.add function indicates the z-index</SPAN>
wayneCoParks <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://devarcgisent.waynecounty.lan/serverdev/rest/services/ParkFinder/Wayne_County_Parks/MapServer"</SPAN><SPAN class="punctuation token">,</SPAN>
sublayers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
popupTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>wayneCoParks<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">19</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Create the MapView for the main map</SPAN>
myView <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"map_canvas"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">83.22511</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">42.24697</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">//Exclude the zoom widget from the UI</SPAN>
ui<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
components<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"attribution"</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">//Add scale bar to the bottom right corner of the view</SPAN>
<SPAN class="keyword token">var</SPAN> scaleBar <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ScaleBar</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> myView
myView<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>scaleBar<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom-trailing"</SPAN>
<SPAN class="comment token">//Constrain the max and min zoom levels</SPAN>
myView<SPAN class="punctuation token">.</SPAN>constraints <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
minZoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
maxZoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">19</SPAN>
<SPAN class="comment token">//Add and remove parks according to features</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".featureCheck"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">checkbox</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN>document<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">".featureCheck"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> trgt <SPAN class="operator token">=</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">attr</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"data-rel"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//This 'if' statement will execute the query and get the query results</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>trgt <SPAN class="operator token">==</SPAN> <SPAN class="string token">"bball"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">is</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".checked"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"checked"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">remove</SPAN><SPAN class="punctuation token">(</SPAN>wayneCoParks<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
qTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>getResults<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"unchecked"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Called once promise is resolved</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getResults</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"in getResults"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> parkResults <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//feature.symbol = parkSymbol</SPAN>
feature<SPAN class="punctuation token">.</SPAN>symbol <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
feature<SPAN class="punctuation token">.</SPAN>popupTemplate <SPAN class="operator token">=</SPAN> resultsPopupTemplate<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Add results to the map</SPAN>
resultsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>parkResults<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Configure popup for Park Features</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN>document<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">ready</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".menu .browse"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">popup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
inline<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
hoverable<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom left"</SPAN><SPAN class="punctuation token">,</SPAN>
delay<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
show<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">300</SPAN><SPAN class="punctuation token">,</SPAN>
hide<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">500</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
