In ArcMap, it is possible to configure the resolution in DPI when exporting a map via "File" > "Export Map".
In ArcGIS Pro, a similar function exists when exporting a layout to PDF via "Share" > "Export Layout" > "Vector PDF". However, when exporting a map to PDF via "Share" > "Export Map" > "Vector PDF", this feature is missing.
I already saw the comments of this post: Export map view to tiff - no dpi setting
In my opinion it should be different for the export to PDF since there is a page "to which you're writing the image".
So are there any plans to implement this feature in future versions of ArcGIS Pro? If so, is there already a confirmed release version?
Best regards,
Paul
