Morning All,
I am struggling with what should be a simple Velocity Feed, but refuses to accept data
The post to the Feed is getting :
< HTTP/1.1 500 Internal Server Error
< Date: Thu, 06 Feb 2025 15:23:27 GMT
< Content-Type: application/json; charset=utf-8
< Content-Length: 72
< Connection: keep-alive
< x-envoy-upstream-service-time: 72
< server: istio-envoy
* Connection #0 to host us2-iot.arcgis.com left intact
{"details":"Error id 56c3d099-a3d5-4592-8f55-e4defe2388ca-1","stack":""}
The Feed Logs show no issues what's so ever. Just an INFO note what I turn on the option.
It's a large JSON object from Weather Stations. The Object checks clean in a JSON Tool. What I think the issue may be, but I am not sure how to work around it is that some elements of the Object that messuare thinks like Snow Depth will have a null value if not present, as 0 is a valid Snow Depth if the sensor is present and active. But the Schema in the Feed is set to a type of float64. "snowDepthCM":null, "snowDepthIN":null
So two questions;
- How do I get this feed to accept the data and pass it to the RTA. I need to understand the Error(s) messages I guess.
- Which leads to the second issue, how does one debug this?
