Hello:
I'm using a SimulatedLocationDataSource to simulate a Track that was previously generated. I would like to change the following while the simulation is running:
1. I would like to adjust the SimulatedVelocity: This is a property of SimulationParameters which is used with the SetLocationsWithPolyline method. Therefore, the only way I know how to do this is by restarting the simulation from the beginning, or stopping the current simulation and reworking the geometry to start at the current location. All of these solutions would lead to a bad user experience. Ideas?
2. I would like my simulation to stop at the End Node. Instead, it goes back to the Start Node when it gets near the end node.
3. I would like to see the simulation follow all of the vertices. My current simulation skips vertices. I think I might be able to do something more elegant by using a RouteTracker with a SimulatedLocationDataSource (this sample demonstrates this:
https://developers.arcgis.com/net/maui/sample-code/navigate-route/ ) However, I need to avoid credit usage for this application (although, maybe credits aren't being used since I'm not having the code figure out a route???).
Thoughts?
