I use ArcMap traverse tool in creating mostly parcels and other features, but ArcGIS Pro traverse is not providing the same report like what we have in ArcMap. When starting the traverse from a point in ArcMap that has coordinates, or any point in the map, and then after entering some cogo lines, I can use the "End" arrow in the traverse window and click anywhere while I'm cogoing to get the end coordinates and the Direction/Distance for a quick misclosure check as provided by the surveyor in the plat or any existing point in the map, especially when we have multiple coordinated points. Sometimes I don't have to do all the cogo because when clicking on some existing points, I can immediately know if the cogo closure is good and I'll just end at that point, and then the misclosure report in ArcMap is helping me reducing the work time.
ArcMap traverse provides; the number of courses, the end coordinates field, and the end point arrow that can be used to check for any point in the map for closure in the report
I hope to get the same or similar report in ArcGIS Pro since our County is transitioning to Pro and I think we will be using 3.3 eventually and also hope this addition can be added to this version!
