Has anyone updated the suite of scripts used in the Fire Service Map solution from ArcMap to work with ArcGIS Pro? In addition were you able to configure the scripts to work with a map series instead of several ArcMap projects (per dispatch area)?
For the most part the settings.py is the main file that needs to be configured for the differences in ArcMap projects vs the ArcGIS Pro map series. I also found that the CreateHydrantMaps.py calls some analysis and buffer functions that I don't think are necessary for my dispatch areas and map exports.
I did see some examples of the map series code in the ESRI literature, but I was hoping there might be some plug and play options available from the Solutions Team.
