Hi all
Requiring some reassurance regarding some workflow I have established for Field Maps data collection. This is building upon lots of stuff I have read on this forum and in the ESRI blogs, but require a hard-and-fast answer.
I need to know if the following process ends up with quality, high-accuracy data, or something that has been transformed into an ugly mess.
1. Field Map set up, creating feature layers based in GDA2020 Zone 56 (an Aussie system), using high accuracy GPS metadata
2. Basemap is ESRI world imagery (for export), making entire Field Map have a CRS of WGS84
3. GNSS set up to collect in GDA2020
4. Field Map location profile is performing a transform GDA2020_To_WGS_1984_2
5. Data collection occurs
I would like to know if I am losing anything in this process, particularly as it reads to me like the data is going GDA2020 > WGS 84 > (then presumably back to) GDA2020 z56. In particular, is the transform happening from the basemap CRS to the required CRS of the feature layers (GDA2020 z56)
Generally I don't have capacity to create my own basemap (therefore avoiding the WGS84) and the feature layers have to be set up in GDA2020 z56.
Anybody got thoughts on this process? Any insight appreciated.
Cheers
