Hey everyone,
I’m hoping to get some advice on a challenge I’m facing with one of our surveys in Survey123. I’m not sure if what I’m trying to do is even possible, so any help would be really appreciated!
We’ve got a pretty big survey with 86 questions, each having a score (most are worth 1 point, 6 are worth 2 points, and 1 is worth 3 points, totaling 100). The survey feeds into a Power BI report and a Power Automate flow, so we can’t make many changes without creating a lot of extra work or causing issues down the line.
Now, my colleagues want a simplified version of the survey for field workers, but they still want it to match the original survey. The tricky part is that the simplified version has fewer questions, but the responses need to fill in the original questions.
I’ve tried adding some conditions in the simplified survey, but I’ve hit a dead end. Multiple questions in the simplified version need to match several questions in the original, and I can’t seem to get the logic right. I also tried linking the last response from the simplified version to the original one, but that didn’t work either.
I thought about using timestamp fields as a workaround, but that’s not ideal since the feature layer is already pretty large, and I’m worried it could cause performance issues.
Has anyone faced something similar or have any ideas on how to make this work?
A few extra details:
- The 86 questions are split into 10 chapters, with names like Q1_1, Q1_2, etc.
- I’ve attached a copy of my attempt (with labels and proprietary info removed) for context.
Thanks so much for any help or ideas!
