Trying to run a Model from a Model by exporting to Python. It's been painful so far but I'm close. One last issue. My Model runs ok and when called from a Master Model it also runs fine. BUT when I export a Python file, then edit to make it overwrite (arcpy.env.overwriteOutput = True) and then paste the script in the Python window I get the following.
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2025-01-20 10:35:23
import arcpy
from DaylightFP.DaylightFPx1 import DaylightFPx1
def MasterModelFP(): # MasterModelFP
# To allow overwriting outputs change overwriteOutput option to True.
main_multipolygons_2_ = "main.multipolygons"
main_lines_2_ = "main.lines"
# Process: DaylightFPx1 (2) (DaylightFPx1) (DaylightFP)
World_8_5_32_98_FP_shp_2_ = "D:\\ESRI-Daylight\\NCERTS_1.0\\World_8_5\\World_8_5_32_-98_FP.shp"
DaylightFPx1(Output_Shapefile=World_8_5_32_98_FP_shp_2_, Input_Polygons=main_multipolygons_2_, Input_Lines=main_lines_2_)
if __name__ == '__main__':
# Global Environment settings
with arcpy.EnvManager(scratchWorkspace="C:\\ArcGIS_Scratch\\NXTScratch.gdb", workspace="C:\\ArcGIS_Scratch\\NXTScratch.gdb"):
MasterModelFP()
File "<string>", line 6, in <module>
ModuleNotFoundError: No module named 'DaylightFP'
I'm sure it's something very simple but I'm at a loss. Help !
