Hi, I'm using the documentation I found here and trying to disallow my users from being able to rename their attachments in Survey123 Connect. I'm pretty sure I have the syntax correct in the correct column based on the documentation, is there anything I may be missing, because I'm not seeing the rename capability being removed when I publish. Thanks in advance!
