ArcGIS Pro 2.9.5
I'm wondering if it would help to have a Clear Selection button in the Select By Attributes and Select By Location windows.
I'm aware there is a Clear button in the Map ribbon tab; that tab might not be open when using the Select tools. I'm also aware that there is a Clear button in the Attribute Table; the Attribute Table might no longer be open when using the Select tools. Regardless, I think it would be more intuitive to have a clear button in the Select windows, since that's where the selection is being performed.
Also, we have established that hitting Apply when there are no selection expressions selects all rows instead of clearing the selection. No SQL expressions in Select By Attributes — Don't select all rows when I hit apply. Since a "blank Apply" can't be used to clear the selection, a Clear button might be a good alternative.
