Hi everyone!
I have a list in an Experience Builder, and that list filters a feature layer in the adjacent map. When I select an item in the list the feature layer filter works and when I unselect the same item in the list the filter resets, as it is expected. However, when I unselect the list feature by clicking in the map instead of clicking on the selected item in the list, the list shows no selection but the filter does not reset. I end up with a list showing no selection at all but a map showing a filtered feature layer. That is highly unintuitive. Is this a bug or a feature?
The reason I want to be able to reset filters by clicking on the map is that I would like to be able to select features by using either the list or the map. This way, the filtered feature layer could be filtered when selected via the list or the map. Now, if I select a list item for filtering and later select a feature frome the map, since the filter is not resetted, the filter sees double and it fails.
Here an exemple of my problem : https://experience.arcgis.com/experience/7ac6f699ca024398bc33d0f48928365a
Thanks for helping!
