Currently, ArcGIS Pro seems to be set up is that you cannot change the zoom settings for the increments at which the software uses for each scroll of the mouse wheel.
For example, in a map, if I scroll 1 increment of the mouse wheel, the scale goes from 1:900,000 to 1:600,000. Instead, I would like 1 increment to be a smaller increment. In this example, the map would go from 1:900,000 to 1:800,000, instead of going to 1:600,000 right away.
There does not seem to be a way to adjust this.
In Option/Map Navigation, there should be a way to adjust the increments....make them bigger or smaller.
Alternatively, have it that when you use the CTRL or Shift keys, it changes the zoom increments (such as CTRL makes the increments smaller and SHIFT makes the increments bigger.
