I am trying to edit a map that my staff use frequently to collect data in the field. In field maps, they are able to select a polygon feature and use the 'add relationship' button to add a point that is related to that polygon feature. I have a large amount of legacy data that needs to be added to the map, and it would be much easier to do this via Pro or in the Web Map.
Unfortunately, my organization still uses 10.9.1, so the option "add a related feature" is not yet available in the pop-up when I select the polygon feature.
What I've been doing in Pro is manually copying the global id from the polygon feature and pasting it into the attribute table of my new point feature, but this is quite tedious. If anyone has any workarounds, I would appreciate it. Thank you!
