I published a feature class from Pro that consists of completely vertical lines (created from 2 points with same xy coords but one z value is the elevation, and the other z value is 0). These display fine in a scene in ArcGIS Pro, but do NOT display in the SceneViewer in ArcGIS Online when I publish as a feature service. I've done all the basic troubleshooting - it's z-enabled, symbology is correct, etc. etc. I can't really check the visualization in the MapViewer for obvious reasons, but since it displayed correctly in Pro I figured it would work in Online.
Am I doing something wrong?
Alternatively I could use the ground-based xy points, and extrude to the altitude, but I can't figure out how to extrude a point by an altitude value in the SceneViewer - it adjusts the width of the 3d symbol, but not the height.
