Hello, I am struggling to get my data to be visible offline. (using ArcGIS Enterprise 11.3)
I have:
- a feature layer which is not hosted in portal (references my registered sde database)
- a related table (relationship is based on Global ID/GUID)
- Tiled basemap
When connected to the internet, everything works as expected, I can create new features in the feature layer, add inspections in the related table etc. It is when I am trying to work offline I am experiencing problems. I have ensured that the layer and tabled are versioned and synced enabled when publishing to portal, I have created offline map areas in the field maps designer and have no errors in the offline configuration section. When I try to download the areas using the mobile app I get a "Sync Failed" General Errors: no data. The basemap tiles appear to download but the layer and table are not visible in the map (red exclamation mark in triangle: layer failed to load).
Any insight would be appreciated
Fiona
