Results from my Query Widget are added as an operational layer (a partial solution for how WAB adds query results with the option to rename and overwrite each time or add as an additional result layer). The idea is that the queried layer can be turned off and the results are printed without clutter. Unfortunately the Query results do not appear on the printed output. Similarly if the results are added to the map via a Data Action (or both Operational Layer and Data Action) they don't print either. Has this always been the case - I don't recall noticing this before. Is this the intended functionality, because this is a significant drawback for us.
Incidentally, the ability to add multiple renamable search results to the layers panel would also be very useful.
