I am not allowed admin access, but I really want to be able to use pro's Conda environment. Currently my only option is to run another Conda install, but in theory, can't I clone the Pro environment to a folder have access to?
Conda suggests this:
Error: Missing write permissions in: C:\ArcGIS\Pro\bin\Python
# You don't appear to have the necessary permissions to update packages
# into the install area 'C:\ArcGIS\Pro\bin\Python'.
# However you can clone this environment into your home directory and
# then make changes to it.
# This may be done using the command:
# $ conda create -n my_arcgispro-py3 --clone=C:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
but if I try it I get an error message:
PermissionError: [WinError 5] Access is denied: 'C:\\ArcGIS\\Pro\\bin\\Python\\nvs\\my_arcgispro-py3'<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Is this possible?
