I am working on an application that uses the ArcGIS JavaScript API 3.x for a map. I have a default print service and secure map services that require a token for access. Both the print service and map services are in the same group in the portal.
To handle token-based authentication, I have configured the proxy and included the following in my HTML:
esri.config.defaults.io.proxyUrl = "../proxy.ashx";
esriConfig.defaults.io.alwaysUseProxy = true;
In my proxy.config file, I have the following entries:
<serverUrl url="https://myserver.com/gis/rest/services/Utilities/PrintingTools/GPServer/"
username="myUser" password="myPassword"
matchAll="true" />
<serverUrl url="https://myserver.com/gis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
matchAll="true" />
<!-- Uncommented the below if needed -->
<!-- <serverUrl url="https://myserver.com/portal/sharing/rest/generateToken"
matchAll="true" /> -->
<serverUrl url="https://myserver.com/gis/rest/services/Utilities/Geometry/GeometryServer"
matchAll="true" />
<serverUrl url="https://myserver.com/gis/rest/services/MapsFeatureServer/"
matchAll="true" />
I’ve implemented the following logic to append a token to the FeatureServer URLs of the map layers before executing the print task:
var token = 'your_token_here';
var params = new PrintParameters();
params.map = this.map;
// Add token to each layer URL if it matches "FeatureServer"
Object.values(params.map._layers).forEach(layer => {
if (layer.url && layer.url.includes("FeatureServer")) {
// Append the token as a query parameter
if (!layer.url.includes("token=")) {
layer.url += (layer.url.includes("?") ? "&" : "?") + `token=${token}`;
console.log(`Token added to layer: ${layer.url}`);
// Now proceed with the print task
var printTask = new PrintTask(printURL);
var ptemplate = new PrintTemplate();
ptemplate.exportOptions = {
width: 500,
height: 500,
dpi: 96
ptemplate.layout = "MAP_ONLY";
params.template = ptemplate;
// Execute the print task
printTask.execute(params,
lang.hitch(this, this.PrintComplete),
lang.hitch(this, this.printError)
Issue:
Even though I’ve added the token to the FeatureServer layer URLs dynamically, the print task fails with the following error:
Error executing tool. Export Web Map Task: Failed to create layer from service at <FeatureServer_URL>. Failed to execute (Export Web Map).
What I’ve Tried:
- Adding the token dynamically to FeatureServer layer URLs before initiating the print task.
- Verifying that the token is valid.
- Ensuring that both the print service and map services are in the same group in the portal.
Question: Is dynamically appending the token to the layer URLs before the print task execution the correct approach? If not, what is the recommended way to handle secure services in a print task?
Any guidance or recommendations would be greatly appreciated!
