The data collected in the field can be uploaded successfully. But, "Sync Failed" was popped up all the time. It says Sync Replica Internal Error.
I checked the troubleshooting blog. It showed that the issue occurred on those layers I shared from ArcGIS Pro to web. The code is "500". I tried changing those layers either editable or non-editable, which does not resolve the issue.
Does anyone have the same issue and have a solution?
Thank you very much!
