I've created a form that contains a repeat that use's a script to enable users to copy the data from one repeat record to the next repeat record (so the fields as pre-populated). This works well apart from for one field which has an 'autocomplete' appearance. When this field is initially blank (for the first record in the repeat) the field is full width (see attached) and if the user tries to use the drop down arrow to browse for an option, or type in an option, the field just flickers and no option can be selected. If the magnifying glass search icon is pressed however the field re-sizes (see attached) to show the refresh button to the right of the field and the field then functions as expected and an option can be entered. On subsequent records in the repeat this isn't an issue as the refresh button automatically shows.
Could this be a potential issue with the refresh button somehow being initially obscured by the field? Just wondering if anyone else has experienced anything similar/has any ideas on how to get around this (or whether this should be raised with Esri Tech support?)
Many thanks
