Hello!
I’m using a survey with a repeat group where users select a crop and then enter several values, such as the cultivated area. The user fills out the repeat group for as many crops as they have.
In a second survey, I’m collecting production data, and I would like to pull the area data for each crop to calculate the yield.
How can I do this?
I've tried the following formula:
pulldata("@layer","getValue","attributes._02122_area_perma_crop","https://services-eu1.arcgis.com/.../FeatureServer/2",concat("_0_farm_identification='",${_0_farm_identification},"'"))
The record ID that each user uses to identify their entries is the farm name, which is common across both surveys.
