If I understand it correctly, when blocks are used for the symbology of (point) feature layers, the rotation of the block will be adjusted according to a value in ab attribute called "ROTATION" or "ANGLE"
Unfortunately, we have stored the rotation value of a symbol in a field called "SYMBOLROTATION". Is there a way to use the values in this attribute to rotate the Autocad blocks?
