I have 2 layers - "poles" and "poleAssembly". I want to display a subset of the poles layer where the features have a relationship with at least one feature in the poleAssembly layer. The relationship is defined by matching the globalID in the poles layer with the poleID in the poleAssembly table.
Here's an example of the data:
poles:
{name: "pole1", globalID: "a"}
{name: "pole2", globalID: "b"}
{name: "pole3", globalID: "c"}
poleAssembly:
{name: "assembly1", poleID: "b"}
{name: "assembly2", poleID: "b"}
{name: "assembly3", poleID: "c"}
{name: "assembly4", poleID: "d"}
In this case, the map should display only pole2 and pole3 because their globalIDs match at least one of the poleAssembly's poleIDs.
I'd like to accomplish this via a SQL statement in either QueryParameter.whereClause or FeatureLayer.definitionExpression.
I've tried the following-
if let polesTable = polesLayer.featureTable as? ServiceFeatureTable {
var params = QueryParameters()
params.whereClause = "EXISTS (SELECT 1 FROM poleAssembly WHERE
poleAssembly.poleID = poles.GlobalID)"
let results = try await polesTable.queryFeatures(using: params)
This throws error 400: "Cannot perform query. Invalid query parameters."
i've also tried this as whereClause "GlobalID IN (SELECT poleID FROM poleAssembly)" with same error
Any help or explanation on how to achieve this filter would be appreciated. Thanks!
