I am working on converting a Water geometric network to the Utility Network. When I enable the UN, I get over 180 errors that indicate a water line has duplicate vertices. But if I run the "Check Geometry" tool, it doesn't find any errors. Is there some difference in the tolerance between the Check Geometry tool and the UN? I can't find any place to change or define a tolerance in either tool.
(I realize I can display the vertex coordinates for each of the lines and determine if there is a duplicate, but that seems pretty labor-intensive if there aren't really any errors.)
Please let me know if you can help. Thanks.
