I am trying to create a 3-D electrical resistivity (ER) map of data I collected. We already did the interpolation in Matlab and I am just trying to create a voxel so we can make different cuts. The data has easting, northing, elevation, and ER data for all the points.
I understand netCDF files are the only supported files to create Voxels. I have tried a couple of different ways to try and make the netCDF file:
- Use Empirical Bayesian Kriging 3D to try and generate a GA layer and then using GA Layer 3D to netCDF
- Use Feature to netCDF for the individual points
Each time I get the following error when trying to make the Voxel layer from the created netCDF for the GA Layer:
"Warning : Dimension 'RecordID' doesn't have an associated variable so equaly spaced values will be assumed ( origin=0, spacing=1)
Warning : Variable 'FL43_3-D_Prediction_0' has an unsupported number of dimensions (1) and will be ignored.
Warning : Variable 'projection' has an unsupported number of dimensions (0) and will be ignored.
Warning : Variable 'x' has an unsupported number of dimensions (1) and will be ignored.
Warning : Variable 'y' has an unsupported number of dimensions (1) and will be ignored.
Warning : Variable 'z' has an unsupported number of dimensions (1) and will be ignored."
And this for the Feature to netCDF
Warning : Dimension`transverse_mercator` has a size of zero and will be ignored.
Warning : Variable 'y' has an unsupported number of dimensions (1) and will be ignored."
Any help on this would be greatly appreciated!
