I have two separate surveys, and I want a relationship between the layers behind the surveys. Both surveys work fine after published without making the following modifications.
- In Pro, export the layers of the two surveys to a fgdb.
- In Pro, build relationship class.
- In Pro, share fgdb layers with relationship class as web layer to enterprise portal.
- In survey123 connect of the two surveys, point submission urls to new layers
After configuring the forms, i get this error on the layer that would be the parent in the relationship :
[{"id":0,"addResults":[{"success":false,"globalId":"{B3DFC754-AB76-43EC-863D-0A3D57C9FDF5}","error":{"code":10500,"description":"Cannot convert a value of type 'String' to 'INTEGER'."},"objectId":null}],"updateResults":[],"deleteResults":[]}]
The other survey with the layer that would be the child in the relationship works successfully. Is it something I am doing with building the relationship in pro? Is this not possible? I dont really undersdtand the error, as I am not trying to do a conversion.
