I am getting this JSON return on a Delete that reads:
"error": {
"code": 400,
"message": "Unable to complete operation.",
"details": [
"Another application is currently editing the version. [sde.DEFAULT]"
Although, it seems to remove the item from the data base. But, the point will still show in the feature layer. Sorta... It will show, then it will disappear. Then later it seems to show again. However, if you look at the table, the record is removed. When it shows, you can click the point and get the attributes for it as if it is there though.
