We have a Survey123 Connect app that we use to collect data on about 35 wells. The survey is run once a quarter, and then is reset at the start of a new quarter (older survey records are deleted). The way the app works is that the first field in the app is a dropdown list that shows the names of the 35 wells to be surveyed (which is filled in using a search function). When the user selects a well from the dropdown list, other fields then get filled in using the pulldata function. The user then completes the survey and submits it.
Our users have asked if there is a way we could modify the app to indicate the wells that have already been surveyed so that they can know which ones they still need to do. The simplest approach would be to just indicate this in the dropdown list:
W-01
W-02 (done)
W-03
W-04 (done)
And then when they submit a survey for another well, say W-01, the dropdown list would be updated after they submit so that the next time someone take a survey the list would be updated to this:
W-01 (done)
W-02 (done)
W-03
W-04 (done)
I know something like this can be done using a webhook and/or Power Automate, but before we go down that route we wanted to see if there might be a way to accomplish this using the functions built into Survey123 Connect or javascript.
So my question is, does anyone have a suggestion for an approach to accomplishing this that doesn't require Power Automate?
