Hi there. I have code which checks if a point is within the visible area of the map. This works fine if the map is not rotated. I'm wondering if this is intended, or if additional handling of rotation is required.
This is roughly what I'm doing:
MapView mapView;
MapObject myMapObject;
public Envelope getVisibleArea() {
Polygon visibleArea = mapView.getVisibleArea();
return (Envelope) GeometryEngine.project(visibleArea.getExtent(), SpatialReferences.getWgs84());
public boolean isMyMapObjectInVisibleArea() {
Envelope visibleAreaEnvelope = getVisibleArea();
Envelope myMapObjectEnvelope= myMapObject.getGeoElement().getGeometry().getExtent();
return GeometryEngine.within(myMapObjectEnvelope, visibleAreaEnvelope);
The map object geometry / coordinates are in WGS84, which is why I project the visible area like that. As long as I don't rotate the map, this works as expected when I pan in-and-out. Once I rotate the map, the map object can be outside of the visible area, yet returns true. I need to go much further out for it to finally return false. Why is that? Does the visible area not account for rotation?
Thanks for any help.
