This article applies to users of the GIS Request Management solution (version1.0) that is deployed in ArcGIS Enterprise 11.3, including users that plan to deploy that solution in ArcGIS Enterprise 11.3 moving forward.
Other users with GIS Request Management deployed in ArGIS Online and in ArcGIS Enterprise releases 11.4 and after should not experience this issue.
The issue
The Effort chart widget in the GIS Activities dashboard does not report as expected.
As effort is added to an activity, the chart is incorrectly summing both the planned and the actual effort hours. The expected behavior is for the planned hours to stay the same and the actual hours to be summed if there are multiple effort records.
For example, if you have an activity that planned to take 20 hours. Then the chart should show “Planned” = 20 and “Actual” = 0. Once an effort record is added to account for 2 hours. The chart shows “Planned” = 20 and “Actual” = 2. If another effort record is added, let’s say to track 5 more hours, the chart now shows “Planned” = 40 and “Actual” = 7.
The recommended solution
Update widget
Remove the existing “Effort” serial chart element and replace with two indicator elements, one showing planned hours and one showing actual hours.
- Search for the GIS Activities dashboard in your ArcGIS Enterprise portal.
- Edit the GIS Activities dashboard
- Remove the Effort serial chart.
- Add a new indicator element.
- Chose the GIS Activities effort for the data source of this indicator.
- Choose Sum under “Statistic”.
- Choose the field “Planned Effort”
- In the General section, update the indicator Name and Add a title - “Planned Effort”.
- Add a new indicator element,
- Choose the field “actualeffort_sum”
- In the General section, update the indicator Name and Add a title “Actual Effort".
Update filters
The following elements need to be updated to filter the two indicators in their “Actions” configuration.
- Open the configuration of each of the following elements and go to the “Action” tab.
- Locate the Planned Effort and Actual Effort indicators.
- Click the switcher to activate the filter of each indicator
- Each indicator must be set to filter individually.
- Do not check “Render only when filtered”
- The list below indicates the source and targets fields.
Table element
Activities – Source and Target fields = GlobalID
Category selectors
Category
Target Field
Status
Status
Category
Activity Category
Team member
Assigned To
Business unit
Business Unit
Submitted on
Submitted On
Planned start date
Planned Start Date
Planned end date
Planned End Date
Planned effort (in hours)
Planned Effort
Resolved on
Resolution Date
Urgent
Urgent
Organizational goal
Organizational Goal
GIS program goal
GIS Program Goal
ArcGIS Capability
ArcGIS Capabilities
